t50ufo1
(t50ufo)
November 11, 2015, 10:51pm
#1
A site I am working on has a Wow slider and in Safari when I publish the whole ccs menu text blinks from bold to light in time with the slides changing. It is OK in Firefox and Chrome. Don’t have an example page live just now. Anyone got any ideas?
Thans
Trevor
It is a known issue that happens because hardware acceleration is invoked with certain 3d transforms.
Try adding -webkit-backface-visibility: hidden; to the menu container via item>Extended under the Div Style tab
An alternative is
-webkit-transform-style: preserve-3d
t50ufo1
(t50ufo)
November 11, 2015, 11:14pm
#4
Thanks Dave
can you clarify the actual entries for the 2 fields name and value
Trevor
name: value separated by the colon
That should have come out like
t50ufo1
(t50ufo)
November 12, 2015, 12:24am
#7
Neither working
entering in name
entering in value
hidden
and
entering in name
entering in value
preserve-3d
No colons - FW does them for you
t50ufo1
(t50ufo)
November 12, 2015, 9:25am
#9
No change Dave
This is odd
I have another site live here with the same thing -
a ccs menu and a wow slider and it is fine here:
http://www.hometecsolutions.co.uk
where the problem on this work in progress is blinking it too uses ccs menu and a wow slider?
http://www.trevormckay.co.uk/formX/parts.html
They may not use the same transitions.
I’m not seeing an issue at http://www.trevormckay.co.uk/formX/parts.html
What version of Safari are you using? And which item(s) did you apply the styles to?
t50ufo1
(t50ufo)
November 13, 2015, 9:46am
#11
Hi Dave
Safari 8.80 on Yos 10.10.5
added item extended to div style to ccs menu item m17
on about us div style
on Products - W3000
i have confirmed applied on FW and re-uploaded
I can have a look at changing the transition of WOW but thought I had used same as other site that was OK
Regards
Not seeing the problem with Safari 9. Ill try and fire up Safari 8 later.
Add both attributes to m17 on your Master and see if that does the trick.
