Why don’t you send me - off list - what your developer gave you and as full a description of what you are trying to do with it, and I’ll see what can be done.
Send it to thebigerns at gmail dot com, but remember to replace the ‘at’ and ‘dot’ with appropriate symbols, and no typos please
Sent from my iPad
On May 14, 2012, at 7:03 AM, “stuart” email@hidden wrote:
Hi all
I have a CCS sheet which I am using to apply as a header and footer which I did previous with the help of Dev. on a old site
But I want to do this in freeway saves time and I will learn loads faster .
The idea being I can create a ccs box apply that to the freeway doc
Is the quickest way make a new name in edit style and then use the extended button and copy the code direct into there…
so the style name now has the structure of the style
Please advice
I understand CSS and the functions of it but Im trying to apply CCS functions into Freeway and this seems the logical route
External Stylesheets Action will help you add this to the page, and the AddSelector Action will let you fine-tune the classname or ID of the element you want to affect.
On May 14, 2012, at 7:03 AM, stuart wrote:
Hi all
Please advice
