[Pro] Changing the Master for 100% of a Site
I am thinking of changing the way the header and the CSS Menu are displayed, I want to fix their position using the Sticker Action, i also want to change some of the graphic properties of the elements involved.
Is there a simple way of specifying a new master for each page or will i have to go through each page manually changing the Master in the Page Inspector?
Thx
John
That will depend on your site construction.
If all your pages are based on the same Master then it is just a case of editing the one.
I would experiment with a new master until I had it the way I wanted it and then copy/paste its contents onto the Main Master I was using.
David,
Thank You.
I have had some problems in the past Copy and Pasting elements between pages so have tried to avoid doing it. I have the new Master working ( i think) .
I will give it a try, and let you know.
Thanks John
David,
Not trusting my own keyboard skills i first created a backup version of the site via Save Archive, then in the new site, selected the Master that i wanted to update and removed the items i was going to replace, copied the selected items from the new Master and pasted them into the original Master…
Worked like a charm.
Thank You
John
Worked like a charm
Yes - I should have suggested that you work on a copy. Just in case!
Glad it wasn’t traumatic.
