Actual freeway question here. I’m wishing to change the encoding from charset=ISO-8859-1 as it appears with Automatic set in document setup, to UTF-8 as I’m getting an A character before a £ sign.
So I’ve changed in the ‘text’ in document setup from ‘Automatic’ to UTF-8. However its not changing the page away from charset=ISO-8859-1, tried force republishing etc.
Website is using Pulse cms with redactor.
I could use a text editor but site might still require a few tweaks in Freeway.
Hmm, is that Freeway 5.5? It could be a bug (that was fixed in 6). If you can’t use 6 then try changing the document type to something other than 4.01 Transitional (just not HTML 3.2).
