[Pro] Chevron action help
I’m designing a site for my photography and wondering if there is a way to apply or insert a css custom code for left & right chevrons ( < & > ) that when clicked on would change the image.
If this isn’t something easy to set up in Freeway would be nice to know too. Thanks.
This really all depends on how you are displaying the images. Are you using Showcase or Exhibeo or one of the Actions like Carousel?
David, I’d use whatever would work best to execute this.
I know there is a Freeway action for Showcase - Gallery/Slideshow that can be used to trigger a larger image from a set of thumbnail images.
I’d like to not have any thumbnails visible and just use the chevrons to cycle from one image to the next.
Here’s an example of what I’d like to do: http://www.colorservicesllc.com
How to execute this in Freeway is where I’m at a loss. Although I suspect it will require some custom css coding.
Have you looked at Carousel - demo Carousel in Freeway
Action - http://actionsforge.com/actions/carousel
Thanks, Dave. I’ll give it whirl.
