[Pro] Clearbox 3 Lightbox for movies/images
Just found and started using a great option to scriptylightbox it’s called clearbox 3 see it at http://www.clearbox.hu/
Pretty easy to get it up and running with Freeway pro
This is how I did it:
Download Clearbox 3
In Freeway insert a Markup item with code e.g.
Then put the clearbox folder into the resources folder
AND UPLOAD TO THE RESOURCES FOLDER ON THE SERVER!!!
In the clearbox.js file make sure your directing it to the clearbox folder (this folder has 3 folders ‘config, language, core’ inside it) in your Resources folder e.g.
var CB_ScriptDir=‘Resources/clearbox’;
Then:
apply a page action of upload external script (which is the clearbox.js)
apply upload stuff action for file/files required (if needed or make sure they site in your Resources folder with the correct href see more on the website http://www.clearbox.hu/)
