I’m getting ready to design my first, “client editable” website using Freeway Pro. After reading through various posts I’ve decided to go with Pulse for the CMS.
The next thing I’ll need to do is integrate a client editable event calendar. What do you guys recommend for that?
Thanks!
What about a Google calendar. It can be displayed within an iFrame on your site.
That’ll work, but I don’t know anything about Google calendars. Are they easy to implement?
Anyone can set up a Google account and create a calendar.
Then using the iFrame action on your FW page you can set the iFrame to the URL of the calendar.
This FW page does it http://www.deltadesign.co/calendar.html but with some tweaks to the styling.
Is there anything Google doesn’t do? That’s pretty slick. Thanks for the info Dave.
