How in freeway 5.5 pro do I see the html code and edit direct
I’m sure its simple I just have never done this before and I need to add a meta tag in the head for Google to verify site
Please don’t cross-post to multiple lists with the same question.
Freeway generates HTML code when you publish, but a Freeway document does not contain or use HTML at all. There’s no “source view” where you can alter the HTML that Freeway will generate per se. What you do have access to are a large number of Markup areas, where you can insert code that will be interpolated into the Freeway-generated layout code.
To learn more about this, have a read through the manual (available free from the Help section of the softpress.com site). Read about the Page / HTML Markup dialog, and the Insert / Markup Item menu commands. Also look at the Item / Extended and Page / Extended dialogs, which offer further refinements in terms of getting code into the “nooks and crannies” between tags.
And if you post an example page, and ask a specific question related to that page about how to get a bit of code into a particular place, any number of us can help you out with that.
Okay. This is easy to fix. In the page, you have the following code (literally):
<meta name="Google SIte Verification" content="google-site-verification: google86b6eb6958be80d6.html">
You need to change the Name value in the Meta Tag editor to be exactly google-site-verification and the Value field to be exactly google86b6eb6958be80d6.html.
Once you’ve done that and re-published, it should work.
