Anyone an idea why my contact form isn’t accessible?
Thx
Erik
http://www.test.graphicid.nl/contact.html
Thx
Erik
The element “wrapper-bottom” is stealing all of the clicks. Check to make sure that the layers aren’t out of order, or if your form is designed inline, that the overflow is set properly on all of the other peer elements within the same parent element.
Thx
Erik
Erik,
What Walter said. Also, try applying the Auto Clearfix action to the page.
Erik, it looks like a layering issue. The html item “wrapper-middle3” is
sitting over the html item the form is in (“item2”).
If you look at the Site/Page pane, you should be able to see the hierarchy
of all the items on your page. The lower in the list equals higher in the
sorting order, so you need to find a way to get “item2” to be lower than
“wrapper-middle3”. Sometimes it’s as easy as selecting the item then using
the Bring Forward or Send Back menu commands, but it really depends on how
you constructed your layout which I cannot tell from here.
Thx
Erik
Thx guys for your feedback, I will check my construction!
