Hello,
I am building 2 new websites in Freeway Pro 7.0.1, and I simply can not get the contact forms to work. I can not even get an error message. Please do not send me to the video tutorial… I have watched it numerous times, to no avail. Can someone please review these sites and send me some useful solutions? I do not write code.
www.bayofthesun.net
www.priceofhappiness.net
P.S. I can not get the responsive video Action to work either. I had to use the non-responsive version, but would like to replace it.
www.bayofthesun.net
On the Bay of the Sun page you aoppear to have added the Send Form action twice.
1 on item4 and another on item3c
Remove it from those 2 until there are no instances of the Send Form action on the page.
Publish once and then reapply the action as a Page Action.
On the Price of Happiness the form action doesn’t appear to be applied to an item that encloses all the form components - remove it and reapply it to the page instead.
Hello,
Thank you for looking at the sites. I dumped the items I had and rebuilt the forms. Still, I am unable to get them to function. I could not even get a Success or Error page to appear. I had to use email links for the contacts. Has anybody else had these issues?
Do so on an otherwise blank page ie just the form and nothing else.
Upload that and we can take a look.
For a simple form layout look at http://www.deltadesign.co/formtest.html
Using this construction the form action is applied to the table itself.
