The URL for the Continue Shopping button comes from a field, named return, that you include in the links to the cart on your website. See the FAQs and the documentation in Support for more details on how to set the field.
In FW you can include this using the following code but as a rule it is based upon what is in the web address field in the upload section plus the page name etc.
But looking at the code on your page this does seem to be set correctly and on the Cart page it is also set correctly. This is the code from your cart page
Why it doesn’t work I think is a question for Mals or your ISP. I wonder if the mntracing site is also on your shared server.
Im trying to find the return field but I can’t find it, there is one return link on the cart setup on the mall’s website but that is after the purchase is done, anyway on that i put the correct link but still i don’t know whats wrong.
Can you explain exactly how you have created your ‘buy this item’ link.
BTW - you have FW 5.4.2 and there is an update to 5.4.3 that does address some issues.
I would suggest that you apply the 5.4.3 update before you do anything else and when I get back to my Mac I will suggest an alternative way of creating your buy button.
If you drop me an email - my email address is in the People section of FWT - then I can send you an example in 5.4.3 that you can try.
