I tried to insert a short animation into a web page using Contribute. I got this message “Exception thrown in native function” and then the program crashed. Is there a problem using EWA with Contribute?
Hi Mike,
I’ve been looking into this issue for you but as I don’t use
Contribute I’m having to go by the results I’m finding from a Google
search. It would appear that you are not alone with this error
although looking through these threads i can’t see exactly what the
issue might be.
Is this the only file that you get this error with? Have you tried
replacing this file with another SWF file and see if that too returns
an error?
If you are still having problems please contact the Softpress support
team who will be happy to help;
Contribute?
