I’m curious to see how creative people have gotten with Showcase. Please post a link if you feel like sharing. ![]()
I left it alone found it hard work
Really? It seemed pretty easy to me.
Hi Kelly
I find Showcase to be pretty straightforward and easy to use. Putting this artist’s portfolio together was a snap:
http://www.fgrasa.com/portfolio.html
You’ll see I also threw in a Carousel for good measure ![]()
Regards
Derek
I have a simple gallery using the clients colour scheme all tucked away in some tabs near the bottom
http://www.newyoubootcamp.com/portugal.html
Derek, I looked at your gallery on an iPhone and the enlarged images couldn’t be seen - they were off the page. Not sure if that’s an iPhone issue but might be worth having a look yourself on an iPhone.
Nathan
Very nice website Nathan. Well done. May I ask what you’re using to achieve the popup images on this page?
http://www.newyoubootcamp.com/press.html
Kelly
Thanks Kelly
I’m using moo tools Slimbox - it works pretty well but does conflict with the Scripty actions that built into freeway. I’m only using moo tools as I needed multiple images in each pop up and the Scripty lightbox only allows for 1 image per pop up
Nathan
Hi Nathan
Thanks for the heads-up! Everything looks OK on my iPhone. The images only show up off the page when I’ve zoomed in, which would seem to make sense. Could that be what you were experiencing?
Derek
Hi Derek,
That should be fixed in 5.6.2.
Cheers,
Thanks, Joe. I’ve just republished with 5.6.2, and when zoomed in the popup image is huge - far lareger than will fit on the screen. When I zoom out again, the image resizes, recenters and looks fine. Is that what is supposed to happen?
Regards, Derek
Is there anyway to change the size of the thumbnails and large image?
You’re right Derek, at 100% it’s fine.
Another under the hood benefit of using the latest version.
Kelly, with moo tools slimbox, you create the thumbnail in FW so you can have it any size you want. The larger image can be any size you want.
With FW showcase you can choose your sizes too.
Nathan
I can’t seem to figure out how that is done. Is there a tutorial someplace that describe sizing?
if thee has the Showcase Application open and on the desk. … is the Inspector showing ?? because , if it ain’t, you are not going to see where to make image size changes. it’s just NOT there - without an Inspector.
you will find it under the “View” pull down menu. which then it will show us the Inspector, then you see (hopefully) the Inspector has three sections, of which the left-most one is going to make you very happy.
cheers,
peter v.
I simply added some borders and and a title block at the bottom of each image and left showcase manage the rest.
http://www.greggallagher.com/southwestgallery.html
Enjoy,
Greg
Yep, found it. All it took was a little tinkering. LOL
you will find it under the “View” pull down menu. which then it will show us the Inspector, then you see (hopefully) the Inspector has three sections, of which the left-most one is going to make you very happy.cheers,
peter v.
