[Pro] Coping a folder of webpages to use for another site
Hello,
On a website I already have, within the Site Folder there is a folder that contains a couple dozen webpages. Now I am building a similar website and I want the exact same folder of webpages to just go easily right into this new website I am building.
Though I have tried searching for this solution on the forum pages, I must not be wording things correctly as I can not find an answer, but this has to have been before.
Thanx for any and all help,
R
You cant copy a complete folder of pages but you can copy them individually and paste them into another FW doc.
You do this by clicking on the page name in the site pane at the left hand side and then Edit>Copy
Then open your other document - click on your Site Folder in the site pane and Edit>Paste
Once there you can put them into folders and move them about.
If it’s a lot of pages, it might be faster to do a Save As and then add the few new pages.
Thanks, went fore the first option. Was hoping that there was a way to copy an entire folder and then just drop it.
Trying out the new 5.5 now trying to finish off a new website in the trial mode before I upgrade.
R
