If your link that you are copying is completely separate from all the other text (not touching another link) then copy should carry over the entire extended link and all of its attributes. It is possible for a space next to your link to have the link applied to it, yet it won’t show up that way in the design interface. If you were to look at the underlying code, it might look like this:
<a href="foo">Link text One </a><a href="bar">Link text Two</a>
On screen, it would look like this:
Link text One Link text Two
But that space in between the two would still be linked, and that’s what’s confusing Freeway in both instances.
Try highlighting the space between the two links and look at the Link picker at the bottom of the window. If it doesn’t say No Link, then make it so. Then you should be able to copy one of the links and paste it anywhere else you like.
On Jan 21, 2013, at 3:18 PM, Robert B wrote:
I had to add a new link to the top nav bar on a site. I pasted it in non formatted from TextEdit as Paste and Match Style.
First thing is it picked up the link from the link next to it. So, I had to take THAT link off the new link and set that up with the new link (hope that makes sense).
I set it up to open in _blank window.
I copied it, then pasted it on another page and had to do all the above steps over again. Does Copy not pick up the link information?
If this is all unclear, please let me know.
Bob
