Thank you Tim, your example looks perfect! I will try this tomorrow.
I am looking to take web design further and I am considering upgrading to Freeway Pro 6. As you will be aware, I do not have your expertise with code. Is it possible to produce the same effect using one of your CSS3 goodies?
Thanks again,
Sent from my iPad
On 21 Oct 2013, at 21:33, Tim Plumb email@hidden wrote:
Yes, quite possibly. Try adding the CSS3 Box Shadow and CSS3 Corners Actions to your Exhibeo gallery item. I’m unable to check this at the moment but will in the morning if you get stuck.
CSS3 goodies?
Thanks again,
Sent from my iPad
Hi David,
I was looking at this quickly this morning and what I forgot last night was that you can’t apply an Action (the CSS3 Corners [1] or CSS3 Shadows Actions [2]) to another Action item (in this case the Exhibeo item). What you can do, however, is to place the Exhibeo item within another HTML and apply the two Actions to this parent box.
As advised, I have managed to add the corners using an HTML parent box and adding CSS3 actions to it.
The “slide” seems to render better than the “Impress” on Android.
Thanks again for your prompt input,
On 22 Oct 2013, at 09:24, Tim Plumb email@hidden wrote:
Hi David,
