If you’re bending the corners with Freeway’s design interface, then hover over the center-point of the curve with your mouse. You should see a tail-less cursor when you get over the center, and a small circle under it. Click and drag that circle toward where the square corner would be. The radius will change until it becomes 0, and the corner is sharp. The corner dimension in the Inspector will become a dash, meaning multiple values.
On Nov 24, 2012, at 12:44 PM, Steve Ainsworth wrote:
Hi All,
Probably a very simple question and sorry for not trying hard enough… but
I have a box and only want the top left and right to have bendy corners - how?
I know how to make the whole box have bendy corners, but not just certain edges.
(via - inspector - Graphic item - shape - corner 0-9px)
