I’m having problems getting certain pages on the above site to scale correctly when in horizontal mode on an iPhone, iPad etc.
Most of the pages on the site scale correctly but on a few of these pages I get a black border on the right hand side when the device is used horizontally.
Can you try this with a completely new document, without using any templates? Draw a graphic box at each corner of the page, and fill it with a color. Add some HTML boxes with text in the middle, just so there’s something else there to work with. Don’t make any of the settings in the mobile section of the Page Inspector, just leave it as default. Then duplicate the page in Freeway, and make one change in the Inspector. Do this as many times as needed to create the range of available options. Then publish this test document and visit it in your devices. (It will be easier to navigate if you either create some links to the various pages, or if you name each page for the option it demonstrates, i.e.: http://www.example.com/device-width.html
On Jan 28, 2014, at 9:08 AM, Tony wrote:
Hi Walter
Thanks for your reply.
Yes I’ve set the width to device width and device night and I’ve also tried setting this to automatic but with the same results.
This anomaly only occurs on 4 of the pages. I’ve checked and looked for stray objects etc but can’t see a thing out of place.
This problem is caused by the g+ stuff which has a width of 450px overlapping to the right. Honestly I don’t know how to fix, but deleting this (for a moment) should fix it.
