Hi, Gang –
I can’t seem to remember the correct terminology for creating a pop-up or a build. Once I’m reminded of that, I can go in to the Reference Manual and find what I’m looking for, but I can’t remember the correct term to do a search.
What I’m thinking about doing is to have a page that builds in a timed sequence. So, when the visitor first arrives, they see the first blog of copy I want them to read, then it builds piece-by-piece after that.
I know there’s a way to do that in Freeway. Can you refresh my memory on what that’s called?
Jamie
