Randi
(Randi)
December 31, 2015, 12:43am
1
Hi.
I want to use a word as a breakpoint icon instead of the default hamburgers, so I created the word at the size I need and saved it as a png. I then selected it as the “open icon” in the CSS Responsive menu action, but when I test the site in the browser, it automatically reduces it to the width of the default hamburger icon and becomes unreadable, regardless of its original size. How can I prevent it from reducing?
Thank you.
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
You will need to add some CSS to your page/site
.fwNav1-toggle-label, .fwNav1-toggle-close {
width: 45px;
height: 45px;
Is what works for me - obviously you will need to play with the width and height to suit your needs.
Dont forget to wrap this in some style Tags and add it to your Page/Master via Page> Html Markup in the before section.
It should then look like this:
<style type="text/css">
width: yourwidthpx;
height: yourheightpx;
</style>
If that doesn’t work for you then post a link to an online example and we can work out what went wrong.
Likes: 1 ❤
Randi
(Randi)
December 31, 2015, 2:31am
3
Thanks! I’ll give it a go and let you know how it works out.
Likes: 1 ❤
Randi
(Randi)
December 31, 2015, 2:19pm
4
Hi,
It’s working to some degree, but not 100%. I tried a few different things (I love troubleshooting), but it’s still not working the way I need it to. I’ll post a link to a sample page.
Thanks for your help, I really appreciate it.
Randi
Likes: 1 ❤
That is the only way we can properly diagnose any issues. When you post a link tell us what you are hoping to see/how you want it to work.
Randi
(Randi)
December 31, 2015, 5:59pm
6
Yes, I will certainly explain in more detail when I post the link. I wanted to create a clean document with just that page and set up a test URL for it., but got hit with an “emergency” project that has to be completed today, so had to switch gears. Will jump back onto it asap.
Happy New Year and thanks again.
~R
Likes: 1 ❤
Randi
(Randi)
January 2, 2016, 11:13pm
7
Happy New Year! I got a little further since last I wrote, but am not completely there yet. Below is the link. There are 2 live page links: “Special Events” (the sample page it’s applied to) and “Example” on which there is a graphic of my goal.
The “Main Menu” icon is working, but it won’t center vertically for some reason. The “Portfolio” menu icon reduces to the default width.
It also seems that the close icon picks up the width written in the HTML page mark-up (with the height resizing proportionally). Is there a way to assign a separate size to the close icon?
http://icontest.rsidentitydesign.com/
Thank you!
Randi
Likes: 1 ❤
Try adjusting the height of #item13 at the relevant BP - about 26px should do it.
If you make your Close icon the same size as the Open one you shouldn’t need to adjust them individually.
Other than that create a new separate style .fwNav1-toggle-close
Randi
(Randi)
January 8, 2016, 11:06am
9
Thank you for all your help!
Likes: 1 ❤
gavtro
August 1, 2016, 6:38pm
10
width: 45px;
height: 45px;
width: yourwidthpx;
Having the same issue. Could someone explain how to implement David’s solution in very simple terms - thanks!
Randi
(Randi)
August 1, 2016, 9:26pm
11
Go to: Page, HTML Mark-up and place the code below in the Before section . Best to apply it to your master page. Replace with height and width values with your own. Mine happen to be 134 x 22px.
Note that I created my Main Menu and and “Close” art in Illustrator and exported them as PNGs. So the dimensions must match or be proportionate to the values you key in. You can see it working on my site: www.rsidentitydesign.com
width: 134px;
height: 22px;
Hope this helps. Maybe someone else can explain more simply.
Likes: 1 ❤
gavtro
August 2, 2016, 8:04pm
12
Thanks. All seems straightforward enough, but still seems to be displaying it at the same vanishingly-small size! Is your solution exactly the same as David’s?
Likes: 1 ❤
Randi
(Randi)
August 2, 2016, 8:36pm
13
Hi. Yes, same as David’s. I wrapped it in style tags as he suggested.
I see that my above code example reverted to one line, as I forgot to create that green box which keeps it intact.
Likes: 1 ❤
Post a link Gavtro and we can have a look.
gavtro
August 3, 2016, 10:54pm
15
Thanks. It’s here:
http://www.test2.thebrandmill.net
(It’s the home page only that’s got the larger hamburger at the moment)
(Excuse the site’s ragged responsiveness - it’s nowhere near finished!)
Likes: 1 ❤
It looks like your text/css is wrapped in curly quotes ” not straight ones "
<style type=”text/css”>.fwNav1-toggle-label, .fwNav1-toggle-close {
width: 135px;
height: 29px;
}</style>
Change that and try it again.
Likes: 1 ❤
gavtro
August 4, 2016, 6:15pm
17
Doh, yes!
That did the trick. Thanks, David.
Likes: 1 ❤
