Hi guys. I need a little help. For some reason the CSS menu on this webpage is acting up, but I have no idea why. All of the other menus in the site seem to be fine. It’s just this page:
Hey David. I setup a style for the menu, and specified the size attribute, but I’m still having issues with it on that particular page. Weird. Any other ideas?
This is clearly the problem. However, I have no idea of why that’s happening. The CSS Menu I use on this page is the very same one I use for the entire site, so there must be something specific to that page that’s causing the problem. Hmmm.
On 27 Jun 2012, 5:54 pm, DeltaDave wrote:
The problem I am seeing on that page is that the headline menu items are turning bold on hover and expanding the text boxes too much.
You can see here that the link when hovered over will change the colour to white, style the text bold, remove any text decoration (underline) and set the background colour to red.
This works well for the tabular data but throws the CSS menu items and footer link into a fit of chaos as the page flexes to fit the new text styling.
Here’s how to fix this;
Click on the pasteboard so nothing is selected
Click on the second tab in the Inspector palette (the brush icon)
In the links section make sure the settings are the same as those on your other pages
Select the “table-container” item
In the links section style the links for this item as you had them previously for the page (step 3)
What you should end up with are links for the page that follow the rest of your site as well as modified links for the table data.
I think the lesson to learn is that if you want to do this sort of thing then you do it on the Master and then you only need to fix it in one place too.
I agree Dave. However, that particular page has a special link setup because I wanted to make sure users understood the purpose of that chart.
I do value your opinion, so when you get a moment please take a look at this page and see if it makes sense to you. Bear in mind that it’s primarily target to older users, above the age of 40.
Well as part of your Target market I find that the Italicised text in the table header is not that distinct and that there is not enough contrast between your gray text and the pale yellow/white background.
For clarity for an old Git I would also prefer a sans serif font.
Red on hover for me also gives a negative/warning feeling - less inclined to click through!
Good observations. Thank you. Yes, I was concerned about the contrast with the gray text as well. Do you think a darker gray would be better or should I just go with black? I find that black is often not quite as sophisticated, but readability is key.
Sans serif. Hmm. I’m trying to limit the amount of sans serif fonts I use so the site has more of a traditional feel. I need to think about that one.
Yeah, I agree. Red does traditionally have a negative connotation. What do you think of a dark pink to match the flower in the header? Assuming that statistics are correct, this site will likely be used more by surviving females anyway.
I agree with Dave about the sans-serif font. Also, more contrast in the
type.
Also, when you have things like “download our park map” you should make
those links – don’t make me go looking for the things you say I need to
download.
Looking good!
52 years experience as a human being
females anyway.
Thanks Ernie. I just updated the page. It’s looking much better. The site is about 85% done. I hear ya about the links. I was planning on doing that, which is why I have a few lines of text reminding me to do certain things.
I do have a few questions though regarding the links.
What do you think is less confusing for an elderly person, a link that opens in a new window or one that simply goes to that page?
How do you feel about PDFs? Should I have them open in the browser, in a new browser window, or just downloaded to the user’s PC?
I think it is bad form to take control of the user experience away from the
user. When it comes to links, let them open in the same window – it is much
easier for the user to override this behavior than when links open new tabs
or windows. Don’t be rude.
PDF’s work the same way I think. Simple links can be opened in the browser
by the user or downloaded – depending on their browser setting and their
choices. What you don’t want is to have the links in your document be
ambiguous – so make your link experiences consistent. If a user doesn’t
know they’re about to open a PDF, they might be put off by the experience.
Give some fair warning, like indicating clearly the link is a pdf. Give
them an idea of the size (111k) or direct them to a page where thay can
have more information and maybe a thumbnail cover to gauge the kind of
reading experience they can expect – I tend to read short text pdfs online
and view long or image-laden pdfs locally.
Best wishes
To me the picture frame with the map in it looks like something I would expect to see on the study wall of an old golfer - and not obvious it is a link to the Pdf.
I think it would also useful to give a Pdf like this a more appropriate name rather than just wmp_map. After a download it is useful when you come across a file like that on your HD - might be next week or next year - to know what it is without having to open it. Especially for us older gits.
So, are you suggesting no picture frame, or something more upscale, like a gold leafed frame? As for the PDF, are you suggesting I spell out the name, instead of using an acronym?
FYI, the site still needs a lot of cleaning up in terms of imagery and design. I’m just not happy with some of the images I’ve selected, or their placement, so I need to search for some better ones today.
Also, took your advice on the links. Went with a traditional underlined link style using primary colors from the site. I think that works much better.
