[Pro] CSS Menu action, problem
The dropdown-menus on this page
http://www.panoramas.no/rog/jarmuseet/fyret/lykten/lykten.html
are not consistent. They are formatted the same, but but behaves differently. The menus with orange text is ok. All are formatted the same in the CSS Menus-action.
Could this be caused by the text-styles?
You appear to have used several CSS menu items rather than incorporate all into 1 and yes I think styling is the likely problem here.
You may have to go through each list and remove all styling - Style>Remove Styling
Because they are not all within the same action you are more likely to get outside styles creeping in to affect some and not all.
Ok, great. Works fine now, the above link does not show the error anymore. Thank you.
