Here’s an odder one. I have employed the css menu action on my master pages. The submenus use a semi-transparent png file as a background image. Randomly, but with annoying regularity, some or all of the sub-menus fail to display the png when the main menu item is rolled over, although it does appear when individual sub-menu items are in the hover state. All it takes to correct the problem is to select the menu, deselect “Use Master Settings,” reselect “Use Master Settings,” and republish. After that, the page behaves normally. To see an example, go to the link below and roll over the lower right three menu items: http://www.christiancaine.com/ccaine/contactus.html
Any thoughts?
Thanks, David
