Does anyone know if its possible to hold the “click effect” in a freeway css menu?
Just Like the rollover action, there we have the option to say “reset: no”
I linked the menu to some anchors and the menu link should stay highlighted till you click on another link.
The example is quick and dirty, the links should stay red after clicking on them.
Maybe there is a script solution?
Does anyone have experience with that kind of stuff?
This uses some js to add a class on clicking the link (removing it from another link if it was already applied)
But as i said this will depend on how your Menu is set up. This example is really for a single page.
You may not wish to use jQuery - the same effect can be achieved in vanilla javascript.
The Code
<script src="http://code.jquery.com/jquery-2.1.4.min.js"></script>
<script type='text/javascript'>//<![CDATA[
$('ul.class-applied-to-menu li a').click(
function(e) {
e.stopPropagation; // stop the click from bubbling
$(this).closest('ul').find('.selected').removeClass('selected');
$(this).parent().addClass('selected');
</script>
The class that is added to each link (onclick) in my example is .selected and you can style that how you like - however you should note that any menu styling (click, hover, active etc.) will likely take precedence so best left off until you have it working as you want.
A purist would say yes, but the semicolon is optional, unless you are going to minimize the page (and lose the line-breaks that mean the same thing as the semicolon).
On Apr 4, 2016, at 8:37 PM, DeltaDave email@hidden wrote:
It sorta works. Kinda.
Works pretty good.
Should there be a semi colon at the end of this line?
The offset is for the fixed nav-item’s height (70px in this example). The name of the css-menu might be different as well (but should match as long it is the first implemented one).
To indicate the bg color of the current link, I created the following Tag-style in the styles-palette:
#fwNav1 .fwCurrent {
background: #E20019;
As ever the simple word of warning (disclaimer):
Dealing with external library (jQuery) may cause, that you have to drop other actions such as Scripty or FX (Scriptaculous/Prototype) to avoid any clash of the titans.
Furthermore I expect people knowing what they do. A “missing” feature or action is neither an excuse nor a constraint.
