I have a Backdraft generated example in the URL. The CSS navigation menu has primary items and then dropdown text, set up in the usual way using Freeway’s bullet point settings. There is a hero image below the navigation (In this case a Exhibeo item). The problem is that the dropdown menu items vanish behind the hero image. Is there a workaround to this so that the dropdown text appears above the hero image?
If I remove the container holding the hero image (Exhibeo or not) the drop down items appear.
Not often that I can answer tech questions … but I imagine the problem is that menu is further back than the image. So, select your css menu and hit Cmd= or go to the Item Menu and choose either Bring to Front, or Bring Forward. (Or choose to send the ‘hero image’ backwards).
Hi Grant, thanks for your reply. Wish it was that simple, but in Backdraft, which creates a fully responsive layout, there is no send to back or send to front option (It is greyed out).
