[Pro] CSS Menu Help
Hi guys,
I’ve got a menu on my website and currently drops downwards on a mouseover.
Would it be possible to make the box go upwards?
example menu I am using:
http://www.sct-photography.co.uk/oldweb
thanks,
Seb
Hi Sebastian.
Of sorts, yes. Try the following Action;
http://www.freewayactions.com/test/css-sub-menu-position/
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
Hi Tim,
I just tried applying in to the menu but nothing happened. I set a negative value to the vertical and still nothing. Am i missing something here?
thanks,
Seb
On 12 Apr 2011, 12:35 pm, Tim Plumb wrote:
Hi Sebastian.
It works OK here… here is the Freeway 5.5 Pro file if you want to pull it apart;
http://dl.dropbox.com/u/1945110/CSSSubMenuTest-fw55pro.zip
On 12 Apr 2011, at 13:43, Sebastian Crewe-Turrell wrote:
Hi Tim,
thanks,
Seb
Hi,
I’ve got it working when I make a menu from scratch in freeway.
However, the menu I am using on my site, I got ages ago from somewhere and for some reason will not work with the sub menu action?
Seb
Hi Tim,
thanks,
Seb
Was your original menu created using the CSS Menu action?
If not then the sub menu action will not work.
No it wasn’t.
That’ll be why…
Seb
