I am new to Freeway Pro. I have prepared a css menu and linked the appropriate pages. When I preview in Safari I can click a link and it goes well. But then when I try to click another link in the same menu nothing happens. Each time I preview the same thing happens with various menu links. Any ideas?
Do you have the CSS menu on a Master page and are you creating the links in the Master menu item.
If so and if you then check on each individual page and select the menu item then look in the Inspector and see if you have the Use Master Content and Use Master Settings boxes ticked.
Thank you for your reply. I have checked these things and they seem to be correct. Yet, I seem to be digging the hole deeper:) Now after tweaking, certain submenus are not active and a few other odd things. Would it be better at this point to delete the css menu and try again from scratch…that is, leaving the pages as is and just redoing the menu?
I have everything almost working now. The only problem I have is when I click on a submenu (under Tasks) I can follow the link once, but when I try to naviagte around and go back, the two lower submenu items blank out and only the first is available. I have tried to check the properties of each and can’t find out what is wrong. Thanks!
