I’m using Walt’s Sticker action on the menu bar at the top of the page.
http://www.andrewdesign.co.nz/service.html
It is currently quite a deep block so as to accommodate the CSS drop-down menu attached to the about button.
Is there a way to have the item called ‘menu-holder’ automatically expand when the menu is activated?
Perhaps I can remake this using the accordion action?
Cheers,
Nik
Ok, I can answer a bit of my own question here. I can’t use accordion as it conflicts with Protaculous.
Any other ideas as how to force an html box to expand with a drop down menu?
Cheers.
But you can use ScriptyAccordion - get it at actionsforge.com
Ok cheers, thank you!
