Hi - I did this site some time ago - the CSS menu was fine but now when you roll over the Tutorial tab only the first of the list greys out? The rest do not, when I rollover?
No idea why this has started doing this -
Any pointers? Cheers
There seems to be several styles added to these links which are competing.
Have you used the Links section in the Inspector as well as the settings in the CSS Menu action? If so then remove the Inspector settings and try it again.
Remember these Link settings can be applied Page wide or Item specifically.
Thanks Dave, I just checked theres a page wide link style applied with the inspector, and the CSS menu action link styles used on the menu - thats normal right? They dont normally conflict?
I havent applied a style to the HTML box that holds the CSS menu?
