Using Freeway 7.1.2. Added a new CSS Menus item. The minimum size for the box can’t be shrunk to less than the size necessary to view/edit the textual List for the CSS Menus.
I have older CSS Menus that can be shrunk to the size of the menu as it’s presented, and they automatically expand if I click into them to edit the list.
This must be a setting I don’t remember from my previous work, but I can’t find it.
The pulldown menus work great otherwise, so I’ve got the basic setup right.
Any advice sincerely appreciated. Thank you in advance.
