I’m trying to figure out why I cannot deselect Underline from the Style options for my CSS dropdown menu. I’ve tried one line at a time, all lines…doesn’t matter. Every line item has a link (except for one line), but I don’t want the links underlined. Any ideas? Thanks!
Try just clicking on the HTML box open inspector, 2nd tab to links and make sure the u with the underline is grey not white. I find this is the issue when I run across the same problem
Julie
Sent from my iPhone
That seemed to work, even though it makes no sense why you have to turn on underlining to make it not underline, but now I have a new problem. The fonts in the css menu are not all the same when viewed in Explorer. They look fine in Safari, and when I preview (go to http://www.paveloc.com/). The whole list is a font set with one font (century gothic), but a few of the items show up as times (or something similar). This software is driving me crazy!
But if you’re styling a CSS menu using the CSS Menu action you shouldn’t have to go the Inspector route UNLESS you set styles for the enter page and not one specific item. By simply not having underline checked it should remove the underlines automatically.
As far as your font issue, what you may want to consider is de-styling everything in the menu and re-applying the styles to make sure it is done correctly. I see on the source code that everything isn’t consistent and that is causing your font issues.
Thanks for your help, but I’ve run out of things to try. The more I mess with it, the worse it seems to get. I’ve de-styled, retyped, created new font sets, new styles… Everything looks and works fine on my Macs, but not in explorer on any windows machine i’ve tried.
