Hello,
I am using the Responsive setting in CSS Menus and I would like to allow for a larger custom image(hamburger). It looks like it is set at 50px x 50px right now. Where is this action located in Freeway?
Hi Billy, I would like to know that too. I made a few icons by myself (positive/negative, crossllined etc) but were I am curious at: what setting can I adjust to get a better positioning?
Only the close icon can be adjusted, but the open button seems to coorperate with the CSS menu… Did you find a trick?
Ok so to allow for a custom size Responsive image here is what to so.
Go to you Applications Folder on your computer >
Find the Freeway Pro Application>
Hold down the control key and click on the application icon>
Select Show Package Contents>
Select Contents>
Select Shared Support>
Select Actions>
Select FAST>
Drag the CSS Navigation action to your text editor>
Expand the Contents Folder>
Expand the Resources Folder>
Expand the Actions Folder>
Click on CSS Menus
In the code on lines 1342 and 1400 you will see height and width set at 30px.
You can edit the size to your liking there.
Richard,
That is a much better solution, however I’m struggling. Could you send me an example of how you set up the tag. I think I’m doing something wrong.
I’ve only added one style to the stylesheet: .fwNav1-toggle-label. Both “width” and “height” have the value “100px !important” (without the quotes). You’ll get it as soon as you see it.
