[Pro] CSS Menus
I have a site that uses CSS Menus as the navigation. Whenever I make a change to the CSS Menus it does weird things to the pages. It shifts embedded pictures around and slides them over to the left side. I am using the action CSS Menus 3.0.8. Thanks!
Maybe this is due to the fact that I am not using a master page to make changes. The site is responsive and it is my first responsive site with Freeway.
It makes sense to use CSS Menus on a master page, but it shouldn’t cause layout problems if you aren’t doing that.
You’re not using the Relative Page Layout Action, are you?
Jeremy
No I am not.
If you send your document (or a cut-down version) to support at softpress dot com, I can take a look at it.
Include some detailed steps on how to reproduce the problem. E.g.
  1. Go to page X
  2. Make this change to CSS Menus
  3. Item [item name] slides to the left
Jeremy
