Okay, sorry. I had not properly divined your page structure. Let’s try again.
Since you’ve changed the page from my last visit, let’s first try
giving yourself a visual aid to understand what is happening. Color
the nav-container box red… that will show you the position of the div
including layering.
You can now easily see that the div is still behind the slider. Let’s
increase the z-index attribute value to something indisputably above
the slider.
z-index:666;
Now, you have tried to position the menu by positioning the container
div. I disagree with that approach. Let’s first match the horizontal
value of the wrapper div which contains the slider.
position:absolute; left:
Then let’s position the menu list separately,
position:absolute; right:66px; width:auto;
Right, so that should text size grow, it expands into the page, not
out of it. Width so that the menu doesn’t break up when text is a bit
larger. I would also add a margin:0; attribute to clear out menu list
margin and use Walter’s Remove Paragraph Tags action on the
nav-wrapper – but those are more personal choices than functional
ones.
I would have built the structure differently, put the nav-container
inside the wrapper div so as to inherit it’s page placement then use
position:absolute to adjust only the vertical position of the
container. It’s important to remember that the unordered list can be
positioned with css too, and in fact doesn’t need an extra wrapper or
container div - just that in Freeway Pro it’s easier to visually
manipulate container html items.
Best,
On Tue, Sep 4, 2012 at 5:00 AM, BigG email@hidden wrote:
The relative positioning makes the menu move around when the browser window is changed.
