What are CSS sprites? Can/does Freeway Pro use it? Is Fill Master using it (ie a gradation fill) or does it just produce a graphic?
Thanks for info!
Helveticus
(Helveticus)
September 30, 2010, 7:47pm
#2
More info on sprites
**CSS Sprites** are not new. In fact, they are a rather well-established technique and have managed to become common practice in Web development. Of course, CSS sprites are not always necessary, but in some situation they can bring significant...
Check out Walt’s tutorial
http://freewaytalk.net/thread/view/59565#m_59579
Great thank you
Paul4
(Paul)
October 1, 2010, 8:06am
#4
I modified a version of the Rollover Action to create CSS3 Sprites.
http://www.actionsworld.com/cssrollovers.php
waltd
(Walter Davis)
October 1, 2010, 12:50pm
#5
Does this Action stitch the images together, so there’s only one GET
for all sprite images on the page? Last I looked at this Action, it
was creating separate images for each state of each rollover, which
isn’t a gain in terms of speeding up the page.
Paul4
(Paul)
October 1, 2010, 10:21pm
#6
No - it’s not clever enough to do that. It just does the job for the element in hand.
