I have FWPro6 and CSS3 Gradient and RGBa_Backgrounds ations installed. These actions don’t show up in my Item/Actions Menu List. Are they compatible with v.6? Are they useful in Pro6?
Hi Daemon
well no and yes I have redone them so they are compatible with fw6, but whilst I was at it… I thought I would make some changes to the CSS3 gradient background version, which i have done I just haven’t had chance to finish everything off… but I can send you the beta’s for now if I can have your email address.
And yes, absolutely useful in fw6, especially since the new gradient has the added facility of adding complicated bespoke gradients
It would be nice to have a new gradient option in Freeway. The one that comes with the v.6 Pro is ok, but it seems that your action has much more solutions.
Unfortunately, I can’t use it in FWPro6. I installed the action (it is placed in the same folder as all my user actions) but it doesn’t show up in Edit/Actions/List. Do you have any idea what could be wrong here?
