Noticed that this action doesn’t even show up in FW6. Softpress noted this action needs to be updated in order for it to work. Does anyone have an idea on when this action will be updated?
Was wondering about this too. So long as you don’t specify HTML5 or XHTML5 as the html output, either on the document setup or individually for a page, it works fine.
The transition from 5.6.5 to a trial version of 6.02 has been remarkably smooth so far, with most problems I’ve had now ironed out. Being able to specify HTML5 of XHTML5 is a remaining fairly minor one.
Right, I’ve noticed the action no longer works when your page is set to output as HTML 5. Would be nice for this action to be updated, it is great with stretchy gradients and transparent backgrounds.
The same is true for CSS3 Shadows & CSS3 Text Shadows. Not so worried about text shadows because it is built in but CSS3 Shadows is needed for inner shadow effects on DIVs.
