I have been trying to use cushy cms for one of my sites so that my client can edit the page himself. Cushy CMS requires that “class=“cushycms”” (outside quotes mine) be inserted before each page item that I want to be made as editable.
I have tried using the page/html markup command with no luck. How should I proceed?
Hi Chris,
try this:
Select the DIV (HTML element), go to “item” → “Extended”, tab “DIV” and click “New”.
Add in the following dialogue without any quotes:
In the name-section: class
and the value: cushycms
This is adding a class of cushycms to this DIV.
Hope this helps and makes cushy working (never tried it btw)
Thomas-
Your suggestion worked like a charm!
Vielen Dank!
Chris
