this time i’ve a question about self created font sets:
i created a font set with souvenir and called it “souvenir”, added the link to the eot and ttf files (@font-face…) lines with html markup in the header and made a new text style with this font set. but when i publish the site, in the head is in the css-line with the name of the new text style the font set name missing (only the name of the secondary fonts are listed, not of the new made font-set)
what did i do wrong? i use freeway 6.0.5 and caxton
you can access the original freeway file with the other relevant files under the dropbox-link http://db.tt/iFboeh2a
as you can see the main menu will be displayed correctly in the master site, in the child sites it will be displayed with verdana …
thank you, now it works!
one more question: the submenu items don’t appear in the preview pane. is that because of the web yep init code don’t work offline, and the submenu will work online as it should?
If all the fonts you are using are contained in one fontface stylesheet.css file then you only require one instance of the Caxton action on your FW page.
So for yours when souvenirlight, souvenirmedium and souvenirlightitalic are within 1 stylesheet the one instance of Caxton will cover them all.
You will still need separate Font Sets for each though.
thank you dave for the hint with the caxton action! i deleted the useless 2 of them.
and yes, you’re right, and i know it, that to preview a site’s looking the php-extension is annoying (sorry for that stupid question, i was fixed in other asks and didn’t think further)
