I’ve created a feedback form for our site and the only thing I’m struggling with is the ‘submit’ button side of things.
Ideally I want to use my own button design that compliments the rest of the site design but I cant seem to find out how to make this custom design into a ‘send message’ type html button as opposed to the stock version that comes with Freeway.
Position the image or graphic that you want to use where you want
it to be.
Select that image and then check the ‘Submit’ checkbox in the image
inspector.
Give it a name of say ‘submit’ if needed.
You should now have a form button that will submit your form.
You will need to set the other aspects needed for a form of course but
now you have an image as a form submit buton.
HTH
On Oct 25, 2009, at 10:47 AM, Paprika wrote:
Dear All,
