I’m trying to set up a page which includes both a Moo Slideshow and a custom scrollbar (using the dom-drag.js method). For some reason they’re not willing to sit with each other on the same page. They work fine on there own.
Yep, the two javascript libraries are competing. As an alternative to the dom-drag.js I found this link on a mootools variety. Does require some coding though…
Thanks for the replies, I might see if I can decypher chuckamuck’s option.
Helveticus, yep, thats were I took a screen grab to use as a test bed for the image transitions. Needless to say I will not be using it on the final site.
