Was wondering if there is a way to create a small popup window on a page, like a scripty lightbox window but just automatically when a page is opened. Thanks!
Check out the Spawn New Window Action, which has a timed option for these sorts of popups. If you set it to iPad mode, you get the new layer like ScriptyLightbox vs. the new complete window.
Draw an HTML box on the page where you want your form to appear. Click once on that box before you draw each part of your window, so that the elements are all contained within the parent box. (You are creating a nested construction element, so you can turn the whole thing off and on as one unit.)
Apply the TransitionFX Action to that outer HTML box. Check “On Page Load”, “Initially Hidden” and set the effect duration and delay you desire.
Done and dusted.
On Sep 27, 2014, at 10:21 AM, Steven Houtzager email@hidden wrote:
Ok, putting aside for a moment that few things will make me leave a site faster than a pop-up, I often wonder how effective this approach is from a marketing perspective. I would really like to see some data because I have a very difficult time believing its usefulness.
if it is controlled by the people who have created the site and it is fairly small, then I think it is useful. The pop up windows I do not like are the blaring ads for something totally unrelated to the site.
This popup/sign up form uses Transition FX to appear on the page on page load. It utilises a cookie so that returning visitors will not see it if they return within 60s (expiry length optional)
