[Pro] Display size
Hi Exhibeo users,
Is there a way to tell Exhibeo how big the display dimensions have to be?
Original small photo’s become blurry because they are displayed too big
thx
Erik
Exhibeo mailing list
Hi Erik,
What theme are you using?
On 1 Nov 2012, at 11:24, Erik email@hidden wrote:
Hi Exhibeo users,
thx
Erik
Hi Joe,
I’m using Focus
www.casasoleada.nl
Erik
For best results in Focus and Bloxx, import landscape images that are at least 1024px wide or portraits that are at least 1024px high. The reason for this is that the theme will export your images images at that size. If it has to scale them up to that size then they are likely to look a little fuzzy.
We’re looking into ways to provide user defined sizes, and to also control how the image is scaled in the browser. Both of these should result in crisper images.
On 1 Nov 2012, at 16:33, Erik email@hidden wrote:
Hi Joe,
I’m using Focus
www.casasoleada.nl
Erik
Thank you Joe,
I’m looking forward to this upgrade,
Erik
Yes, I would love to be able to control display size- currently, the size seems a bit clunky.
Also, where can other themes be found?
Any ideas when this is coming… I am converting older web sites where I cannot go back and scale up the originals from 700 x 497 (497 x 700)… Seems a pretty basic need… Thanks
Try Alien Skin’s Blow-Up (if you’re on a Mac).
Does a fabulous job (for me).
Thanks… Just checked out the site, will test the software and get back to you…
Appreciate the advise on the Blow-Up, works great… Now the issue is the gallery expands to the entire browser window and is not constrained within the page and I am unable to find any settings…
Glad it works;
sorry, can’t help there…
I’ve the same problem, but in my case, nobody cares…
