What does this message mean…
“One or more HTML files which do not belong to this site will be overwritten. Do you want to continue?”
It appeared when attempting to upload. I just switched from 5.6.5 to 6.1. Is there a way to get around this? I am testing the trial to see if all is compatible.
I don’t know if this is to blame, but I got this same message when testing 7, went ahead with it and totally screwed up the site. All kinds of simple html typing was deleted, cs3 menus did not render correctly.
In the example, all author fields were filled in before the 7 upload. In the cs3 menu, all enties were uniform in size before. CS3 menu does not respond to any attempt to bring it back in line. It looks fine before editing.
Glenn
http://www.thesonsofthelawofone.com/thelawofonelibrb.html
