What is the easiest way to create a drop down menu? Online it says css menu option,but not really sure how to do it with that
What sort of menu?
For a menu picking list you use Insert>Menu/List populate it and then ensure that it is 1 item high.
There is also the Navigation Popup Action
Howard - As mentioned previously, all you need to do is to search the KnowledgeBase to find the KB article on the CSS Menus Action at http://www.softpress.com/kb/questions/344/.
There is also a movie tutorial at http://www.softpress.com/help/tutorials/ (called “CSS Menus”) - though that is a little now, but still very relevant.
Note, however, that the CSS Menus Action in FW7 has been updated with two new features. Read about that in the Freeway 7 Reference Extension you can download from http://www.softpress.com/freeway-pro/ under the Free Trial button.
