Richard3
(Richard)
December 28, 2013, 3:14pm
1
An issue that I’ve run into is that a drop down navigation menu’s links don’t work if they run into an HTML item box.
Is there a setting I need to set to make sure the drop down menu works over an HTML item?
Thanks.
Yup, pilgim! Had the same issue when I did this. It only took me 4 ower to find answer. Here it is almost instantly.
Select whatever will be behind the pulldown and make it go behind. Then select pulldown and make it come forward. Then LOCK those items.
Yer entirely welcome pardner.
Holmes the Elder…
Thanks.
Richard3
(Richard)
December 28, 2013, 4:23pm
3
Thanks, Holmes.
I see how I can send the HTML item backwards and lock it, but I don’t see a way to bring my css drop down menu forward.
There is a mode where you can see the drop down with everything extended. In that mode you select the whole menu item and bring it forward and lock it.
On Dec 28, 2013, at 10:23 AM, “Richard” email@hidden wrote:
Thanks, Holmes.
