Hi All,
I started a blank template and I was wondering how I would remove the drop shadow from the website (on the right side of the page)…the only reason is because it shows up when I preview the site I’ve created…and messes up how the background appears.
Thanks!
freewaytalk mailing list email@hidden Update your subscriptions at: http://freewaytalk.net/person/options
That drop shadow is only a visual indicator in the FW doc of the page edge.
It does not manifest when the site is online
If there is a shadow at the edge of your page then it is caused by something else.
Do you have a link to your page online so that we can have a look?
