DUPLIC ACTION FILES, but location for both is the same!
The supposedly duplicately named file(s) are located in the same identical spot, when I go to those files location there is only one of the named files not two, what then. I keep getting this message each time I boot FWP up!
Why not try deleting/moving the one you can see.
Then see what happens on launch.
Well, at least it still opens and that javascript is gone. We shall see, what we shall see, what else can we see, eh? heh heh
Which action gave the error?
Is it still available to use - if so then I guess there was more than 1 version but maybe not where you thought it was.
It was this one:
Navigation Popup Default.fwaction.
Probably, but the javascript put both of them in the exact same place.
