Is there a preferred/recommended e-commerce program that will work well and easy-to-use with Freeway Pro (current version)?
The Mal’s commerce actions are bundled into Freeway Pro so I’d look at that first off. The manual should help you out here.
Thanks David, I can’t seem to any reference to it in the manual - do you know where it is. I looked for information on this in the Actions Forge too.
Elizabeth
Look for mention of Freeway Shop Actions. These are a cut down version of Tim Plumb’s Mals E-Commerce Actions (http://freewayactions.com) so you may refer to those for further detail. Think of Tim’s full version as “Freeway Shop Pro”, they have more features and customizability than Freeway Shop.
Elizabeth
Bear in mind that requirements vary wildly between clients - as do cart offerings.
If your needs are fairly straightforward then the built in Shop actions will do pretty much all you need but if you have specific needs then let us know and we can guide you better.
The built-in actions include E-Shop Settings, E-Buy Form, E-Quantity, E-Product Variation, E-Buy Text etc.
Have a look at http://www.softpress.com/kb/questions/141/Creating+a+Shopping+Cart+in+Freeway
