I made an E-buy form with inside the E-Product variation. So far works fine. The visitors can select the desired color of the product the want to buy.
The issue is that when selecting their color, the visitors do not see what the product looks like in the selected color.
I’d like to know if there is any possibility to connect the color selector (E-Product variation action) to a picture shown the wanted product in the selected color.
Thanks, you are right not to underestimate the clients.
Some of the products are in more different colors available and I was just wandering if there was an easy connection in the E-Product variation action. Hand coding is not what I had in mind so I think I will make a color-overview graphic in order to show the variation.
